Search the Community
Showing results for tags 'spectral correction'.
  • Search By Tags
  • Search By Author
Content Type
Forums
    • Latest news
    • PVsyst main changes
  • FAQ (read only)
    • Meteo data
    • PV Components
    • Shadings and tracking
    • Simulations : parameters
    • Simulations : results
  • Your questions about PVsyst
    • How-to
    • Problems / Bugs
    • Meteo data
    • PV Components
    • Simulations
    • Suggestions
    • How-to
    • Problems / Bugs
    • Suggestions
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
About Me
Found 2 results
  1. Hi, I'm curious how / where the spectral correction model (e.g. when using First Solar) is applied. It's reported as a power correction in the output file; when I compare that power correction to Earray (or EarrMPP), the relative difference is close to - but not exactly the same - as the spectral correction factor calculated with the Gueymard & Panchula/Lee models. Is the correction applied to one of the irradiance quantities, and if so - which one? Thanks! -Johan
  2. Hi, I model utility scale n-type mono crystalline PV modules. I am not sure what settings for Spectral Correction I should use. I am aware that the FirstSolar model is not considered reliable. However, I would like to take into account the Spectral Correction for PV modules in the Sandia Database. To my understanding, even if the module used is not available in the database, a similar module is selected for the spectral correction. Is below the correct way of setting the spectral correction, in this case? Thanks!
