joshferguson
Everything posted by joshferguson
  1. I adjusted the layer name in Autocad and made sure it fell in line with the actual modules and had no success. Im still getting 0's when I import the .dae
  2. Running into some issues when trying to import a .dae file, originating from autocad. Ive gone through the process of converting from: .dxf>.fbx>.dae using the Autodesk FBX Converter tool as mentioned in the help topics. The issue is that, when imported, its showing 0 Faces, 0 vertices, 0 objects. I had some luck with one particular .dae file, showing me 2 faces, and giving me the selection option on the additional tab of "Materials". But when that one was imported, it pulled two oddly shaped rectangles that had 0 correspondence with the actual design. Im at a bit of a loss here since re-creating a actual layout in the construction window is extremely tedious, time consuming, and often resulting is failure to replicate. Ive followed the help topics for importing from Sketchup and Autocad, but it doesnt seem to be granular enough. Any assistance is greatly appreciated. Also open to suggestions to replicating a designed array in the construction/perspective tab. One that falls outside of a typical rectangle.
