Hello, I am trying calculate monthly soiling loss as a % using the monthly losses in kWh. I was using the equation (kWh Loss/(kWh Loss + Energy Injected into Grid)). However, I found that if I use this same equation on the Annual Soiling Loss and Annual Energy injected into Grid, I do not get the same % Loss that is in the Loss diagram. In this situation, I have the following annual values: Soiling Loss (from output table): 45255 kWh  Energy Injected into Grid (from Loss Diagram): 1289957 kWh Soiling Loss (from Loss Diagram): 3.1% 45255/(45255+1289957) = 3.39% I also tried dividing the loss by the Nominal Array Energy at STC (1627062 kWh), which gave 2.78% Could you tell me what value I should be using to find Soiling Loss as a percent?  Thanks
