bris
  1. Hello, I am using PVsyst version 6.66 and trying to simulate a project with Trina Bifacial 345Wp installed in a 1-axis tracker N-S orientation. However, the PVsyst notified that bifacial could only be define using with fixed planes. Is this for real? I just visited a actual solar plant using tracker system using Trina double glass. Is there anything that I need to adjust in my PVsyst setting account? This is quite important as all our project aim is to optimize the maximum output that it could produce. Thank you. Regards, Bris
  2. Hi there, I just want to clarify if the setting of "Rs from Low-light efficiencies" under the definition of a PV module are depending from the module pan file OR it depends with the PVsyst version? I've tried to replaced a certain project of different kind of module and some modules showing this setting but other types are not. Appreciate your kind review and explanation regarding this as this is giving a significant impact on the generation output of the project. Snapshot can be view from the link below. https://www.dropbox.com/s/50f2djyqv8tefq0/Rs%20Low-light%20efficiency.PNG?dl=0 Thanks, Bris
  3. Hi Sylvain, This is quite confidential company information and I think I am not allowed to send the file. Is there any alternative ways to figure out? Thanks, Bris
  4. Hello, I've run a simulation from 6.64 and now upgraded my version to 6.66. However, when I open the project in 6.66, it does not show the full report starting page 3 and up to 5. I have upgraded my graphics but still showing the same. Appreciate your advise. Photo could be find in the link below. Fyr. https://www.dropbox.com/s/dy4h8nptp3g8da6/incomplete%20report%20_pVsyst.PNG?dl=0 Thanks and regards, Bris
  5. Hi there, I have successfully converted my plots from kmz to DAE, using FBX converter unfortunately it doesn't load into PVsyst when I imported it. Does it something to do with my Autocad version? because I am only using Autocad LT? Do i need to use an Autocad 3D? I have tried another option scenario for importing my plot, that is to use global mapper to convert my kmz file to csv but still it did not load once I import it in the PVsyts as it says that less than 3 points have been found. :( Appreciate your kind response the soonest. Kind regards, Bris
