I am Trying to run Batch Mode for Fixed Tilt. Having error message "plane orientation" Plane Tilt is checked "system parameters" Number of strings is checked "Losses" AC and DC is checked "Result variable specification" Energy injected to Grid and Global INC on collector plane is checked After this step i open the batch parameter .csv file. use "Data, text to column, delimited, semicolon, finish in xl " Then copied Rows starting with SIM_1 for 20 times. Saved and closed csv Then hit simulation, get an warning message Error in Batch parameters. Did not find any column for ShedTilt in file. carefully check ur parameter file. If i check my parameter file i can see shedtilt column. Then why is error message comming up Regards Arati
