thangtamfive
  1. When importing a row from the PVsyst Excel PAN file database to generate a PAN file, if the field for the quadratic factor BRev is left empty, the value of BRev in the PAN file will result in 3.2 mA/V^2 regardless of the module's Isc. I do not know what this value of 3.2 represents, but I believe it should be using the default BRev parameter that is specified in the Hidden Parameters for PV Modules, as follows: Quadratic factor BRev [mA/V^2] = 1.2 * Isc, where 1.2 is the default BRev parameter listed in units of [mA/V^2]/Isc in the Hidden Parameters for PV Modules. Thus, if BRev is left empty in the Excel spreadsheet for a module that has an Isc of 8.986 A, I believe the value of BRev in the PAN file should be 1.2 * 8.986 = 10.7832 mA/V^2 after importing, not 3.2 mA/V^2
