Sylvain Pepoli
Administrators
Everything posted by Sylvain Pepoli
  1. Hello, Can you please send us some sample projects in which this happens everytime ? Send it to support@pvsyst.com and we'll have a look, it's really weird that PVsyst shuts down this way.
  2. Hello brunok, The orientation is defined by the normal of the PV fields plane, in the global referential. So it is a combination of the field's tilt, azimuth and baseslope. It seems like you placed your fields on the rooftop and then rotated the whole scene, so in this case the baseslope should be the roof angle. Placing your fields on the ground would get you a -23° azimuth, but here they're tilted along the roof. Which orientations does PVsyst detect when you open the orientations tool (Tools -> Edit orientations) ? It seems like you defined two separate orientations (on each side of roofs) but you only get one in the end ?
  3. Hello Adrien, What you seem to be misunderstanding is that the "PV objects" tab is not listing the objects found in the imported file but the materials. We chose to rely on the material instead of the objects because : - we can't convert full objects to PV faces, as this would mean that if you defined a parallelepiped PV module all of its 6 faces would be transformed to PV faces, - the material is easy to apply on faces in 3D modeling software, and it is always copied along with the object when you duplicate it - it's easier to select one or two materials than hundreds or thousands of objects for complex scenes So if you define a "PV face" material in Sketchup or AutoCAD and apply it on the real PV face of your objects, then you should be able to select it after you import the DAE file in PVsyst. About the settings information you're asking for, there shouldn't be any particular setting needed, the default ones should export and convert the materials correctly. The only advice I could give you would be to try to keep things simple, the complexity of the scene geometry has a direct impact on shadings calculation time. However you may want to have a very detailed and good-looking scene on your simulation report, in this case you may consider disabling shadow casting for objects which you know won't project any shadow on your PV fields, and this will ease calculations. I hope I could help you on that, you seem to be using this new import feature quite intensively which is great ! Sylvain
  4. Hello Jose, Do you confirm that it's okay now in version 6.66 ?
  5. Hello, As solarguru suggested you can indeed delete the unwanted tables afterwards. We are aware that an "excluded-parts" feature would be a great enhancement for the tool though !
  6. Hello Hennie, Please try to open the shadings scene and click on "Tools -> Edit orientations", and then click on "Identify orientations". This should fix the identification in the shadings. This kind of situations should not happen anymore with version 6.65 to be released soon, as this is something we have fixed already.
  7. Hello Bris, Can you send us the files you are trying to import (CSV and DAE) to support at pvsyst.com ? We'll have a look and try to help you.
  8. Hello, Are you talking about the modules layout you see when going to the "By modules" tab of the fields editing dialog ? If yes, then this is an information we don't import from Helios3D, that would be interesting to import it though.
  9. @solarguru Yes, you can select your objects and then click on the menu "Edit -> Set auto. altitude", this will show a panel at the right with a few options for it.
  10. Hello, If one module is one 3D PV field, then you will need to use the Module Layout part in order to simulate the electrical effects. You will also get the bypass diodes calculations if you do so. What was not working when you didn't separate them in Sketchup ? Could you provide us with some DAE files by mail ?
  11. Hello, Please make sure that you have enabled 3D acceleration for the virtual machine. Also make sure that the host graphics drivers are up-to-date, more info here :
  12. Hello there, We have identified and fixed an issue happening when loading shading scenes, modules layout parameters were not read properly and therefore PVsyst was getting an automatic layout everytime. This will be fixed in version 6.65.
  13. Hello there, This is something which should have been fixed in version 6.64. There was indeed an issue with the displayed value of the orientation when a baseslope was defined, it was also fixed automatically after saving/reopening the variant.
  14. Hello, The new shading scene has been tested on VMWare and VirtualBox environments without issues, we didn't test it on Hyper-V. You need to make sure that you enabled 2D/3D acceleration for the guest and that the display drivers are up-to-date and support OpenGL 2.1 on the host. With the recent improvements in the scene this is now a requirement.
  15. Hello, Have a look at the PVsyst help. There are new sections about the new tool and three use cases detailing when and how to use it.
  16. Hello Debbie, There have been many improvements and fixes in the shadings algorithm since version 6.60, so you should rely on the latest versions. There is indeed a lower diffuse factor in your project.
  17. Thanks for the suggestion, The grouped modification is currently basic, on only a few parameters. But I agree that this would be helpful to have all common parameters available given the current selection.
  18. You should be able to select the source unit in the dialog opening after the import, isn't this working ?
  19. Hello, Well the one on top should be the latest added to the scene. There's currently no way to switch it in PVsyst but you should try to manually edit the variant file (.VCx) : look for the two "pvShdGroundImage" blocks and switch them, then save the file and close it.
  20. Make sure you click on "Apply" after you defined the X1 and X2 points or else nothing will happen.
  21. Hello, You can import ground data as ASCII XYZ, using the menu "File -> Import -> Import ground data (CSV)". About shading objects and PV tables, you can import scenes from Sketchup or AutoCAD in the latest version of PVsyst. You can check out the PVsyst help (F1) to get more details about these two imports.
  22. Hello, Are you trying to use the "Module layout" part on a 60MW plant ? If yes, then you should avoid to do so as it has not been designed to handle such big installations. You can use string partitions calculations instead to be able to simulate the electrical effect on module strings.
  23. Hello, Could you please export the shading scene (.SHD) and send it to us at support@pvsyst.com ? I just tried to fill some polygonal zones with automatic length and didn't get this kind of behaviour, so maybe there's something special in your scene.
  24. Hello, Thanks for reporting this, the image base width is indeed reset after being read. We have fixed it for the next version.
  25. Thank you for reporting this and for sending the file, there is indeed an issue with the baseslope being negative when it should be positive, during the conversion of objects to PV fields. We've fixed it and we'll try to release a new version soon.
