rocky
Everything posted by rocky
  1. I am getting very strange results when creating 8760 data. When choosing standard options (see attached options): Options I receive extra data columns with no label as well as obviously incorrect data populated in the labeled columns (see attached results): Results
  2. Thank you for your response! In regards to the shade scene not being saved, let me clarify: We do close the shade scene as described. When we reload the project, the shade scene is not "lost", but rather the program assumes multi-orientations are being used. Original: Then click OK, and close the project and re-open the project: Then open near shadings: "Update Orientation Parameters" changes the Shadings to Multi-Orientation, which we do not want. We want to use the near shadings definition. Thank you, -rocky
  3. Hello, We have a few instances that cause PVsyst to crash while constructing the 3D shading scene. 1. Once the scene is built, choosing "Enable Real-Time Shadows" under the View menu will cause a crash. (The 3D scene consists only of a simple imported *.dae terrain file and a zone-filled array of approx 100 pv planes.) 2. When configuring the zone, choosing "Field Properties" under the tool tab will cause a crash. (Same scene as above.) One additional inconvenience is that switching from one variant to another, or reloading the project file, loses the 3D shading scene definition. I.e., we need to rebuild the shading scene each time we reload the project file or variant. Otherwise it defaults back to the original orientation parameters each time. Many thanks for looking into these issues. -Rocky
