I don't think there is a way to modify multiple objects at once. However, I've found a slight workaround that may work for you. If you place an object below your array with a given tilt, say a roof with a roof angle of 20 degrees, and select Tools>position tables on scene, all the objects should adjust to the tilt of that roof angle.
