vishal
  1. vishal
    Wind velocity
    In the equation U=Uc+Uv *V if I Change the Uv value of the constant how it will affect the output module temperature and power? Please define the formula for the constant Uv.
  2. I completely agree with you I put the right file and it work also but only its showing the error of time shift by 81 minutes at the end even the metero file is created with the error. But i did not find the answer for the error and how its affect my metero file. Please reply
  3. Hi, I import the actual measured data in to PV syst in ASCII format after conversion the values i get for the particular date is different than the actual measured values can you please tel me why is so? And what is error men your time shifted by 81 minutes? and waht is Record time lable?
