jaya
  1. Hi, I have a project which has AE 500 NX -H inverter created in version 6.3.9 but the same project after updating my PVsyst to 6.4.3 is giving an error message to the project saying Inverter invalid as see in the attached image. Could you please let me know any solution to this problem. Thank you, Jaya
  2. Hi , Try saving the scene and close the shading window from the file menu. Hope it works, Thank you, Jaya
  3. Hi Andre, I figured out the issue. We should not close the shading scene window on the X mark at the top right corner, it should should be closed from the close option under file menu in the shading scene. Thank you, Jaya
  4. Hi Andre, The shading scene is present and I did the shadow animation, still its showing as No scene. Thank you, Jaya
  5. Hi, I constructed a scene and saved it. But when I am trying to run the table for the shading scene its showing the error as No shading scene defined. Could you please help me out on this issue. I am using version 6.34. Thank you, Jaya
