CalSolar
Everything posted by CalSolar
  1. Same here, at version 7.2 and the error message is still going strong.
  2. Is it possible to revert to the report format from the previous version of PVsyst? the new V7.1 format is visually inefficient and not working with older projects. TOC is in the wrong place, losses and system parameters are now scattered to four pages, plus the page count increased with no extra information being added.
  3. Did this bug ever get fixed? Im still getting this error in v7.1
  4. I am getting this same message in version 6.46 and the same after I upgraded to 6.47. Is their a workaround this bug?
  5. I now know what the problem was. I was not including file extensions in the file name.
  6. I think their maybe a bug in the current version of this feature. After following your procedure: When defining the batch mode, you should tick "Create Hourly File". If you do that, when exiting the batch mode dialog, the dialog for the definition of Hourly files appears after the message : "You have to define the contents of your hourly file". However you can also define the output CSV file by the button "Output file". This will not generate hourly files despite providing a file name for each simulation line. The following batch file is generated by PVsyst. Ident;Create hourly;Nb strings;Simul ;file;in parall;Comment ;File name;; ;;; SIM_1; N;2560;
  7. I too have not been able to generate hourly files using the instructions you gave above. I am working off of version 6.34 on a Windows 7 machine. Is this function currently working?
