icicle
Everything posted by icicle
  1. If I were to do multiple simulations of different facilities, but they are in the same area, meaning they are on the same block, and I will import a weather data from meteonorm, can I just use the same .MET and .SIT file for all of them?
  2. How can I account for the degradation losses in PVsyst 7? What I want to input are the following: 1st year degradation: 1% Succeeding years' degradation: 0.44% loss per year
  3. Hi. How can I run a simulation using a microinverter? Also, how can I include a microinverter in the database? Thank you.
  4. I have here this P50-P90 report. What is the meaning of variability and why does it have a value of 208 MWh?
  5. What are the factors that affect a high specific production and P90 value? I am working on multiple simulations and there is one simulation that always has a high yield (kWh/kWp/day) and I can't figure out why.
  6. Can this be applied when I am importing a DAE file?
  7. I have encoded a list of monthly values (kWh/month) in the Self-consumption parameters. It resulted in an average power in kW. I would like to ask how the software computes this value. Also, can this average power (kW) be a basis for the kWac of the system that I will be designing?
  8. Hi. How can I add a jea roof safety of 1 meter on each side of zones in Near Shadings?
  9. Can I use the batch simulation feature instead when I have many inverters? If so, how can I use this?
  10. Just to follow up on this. Let's say my whole system has 2 inverters. If I want to know the output of each inverter individually, I need to do two variants, with each variant having the defined inverters of my system. Then, if I run that and extract the csv file, will the E_grid of the two variants add up to the E_grid of the variant for the whole system? With this, can I say that this is how I can proportionate the output of the inverters?
  11. For your suggested workaround, how can I do that in PVsyst 7?
  12. Is there a way for me to view the result of a simulation per inverter stated in the System? For instance, the project has three inverters. I want to see the simulation result for each inverter that I placed in the csv file (time series data). Thank you.
