buffelkip
  1. Hi, I am simulating a large-scale ground mounted PV project with fixed tilt orientation. Due to the slope of the terrain, each PV table has a slightly different orientation. When importing the H2P file, I get the error as shown below. In Version 7, I remember I was able to adjust the tolerance in the Orientations Management tab. That seems not possible now. Could you please let me know how to resolve this? Many thanks!
  2. Hi, I model utility scale n-type mono crystalline PV modules. I am not sure what settings for Spectral Correction I should use. I am aware that the FirstSolar model is not considered reliable. However, I would like to take into account the Spectral Correction for PV modules in the Sandia Database. To my understanding, even if the module used is not available in the database, a similar module is selected for the spectral correction. Is below the correct way of setting the spectral correction, in this case? Thanks!
