Hi Rafael,
I understand your frustration with the optimization tool not working as expected. It's indeed a useful tool when it works correctly.
Here are a few things you could try:
Check the Tool's Documentation: Ensure you're following the correct steps and parameters for the optimization tool.
Simplify the Model: Try simplifying your model by reducing the number of components or constraints. Sometimes, complex models can hinder the optimization process.
Experiment with Different Initial Values: Starting with different initial values might lead to different optimization results.
Adjust the Optimization Algorithm: If the default algorithm isn't working, try experimenting with other algorithms or tweaking their parameters.
Consider a Different Optimization Tool: If the built-in tool continues to be problematic, you might want to explore other optimization software or libraries.
If you're still encountering issues, consider posting a more detailed description of your problem to a specific forum or community related to your field. You might get more tailored advice and troubleshooting tips.
Remember, optimization is often an iterative process. Don't get discouraged if it doesn't work perfectly the first time. Keep experimenting and refining your approach.
I hope this helps!
