obulshteyn
Everything posted by obulshteyn
  1. I've watched the video, but the video does not show how to match the number of modules between the 3D fields and subarrays... how do I make my orientations management tool window look like the one in the video??
  2. Also, I am noticing the following limitation of the software: in the 3D scene there is a way to specify the width and the length of a PV surface while in the system definition there is only an option to specify the area of a PV surface making the whole process of matching the number of PV modules between the 3D scene and the system definition cumbersome at best... unless I am missing something
  3. Thank you for your response, but the reason why I posted to this forum is because I could not correct the errors myself. Is there a way to request a call via MS Teams so I can share my computer screen and someone from PVsyst support will provide the assistance?
  4. I am designing a hybrid (roof + carport) PV system and getting several error messages referenced in the attachments. Could you help me to correct the errors?
  5. The Solar Edge SE50KUS inverter Three Phase Inverter with Synergy Technology has the output power rating of 50kW, however, in PVsyst its output power rating is indicated as 16.7kW... Could you please look into this?
  6. I am working on a PV system project that requires BABA-compliant PV modules, inverters, and BESS to be specified: Build America, Buy America (BABA)-Compliant Solar Manufactured Products | Department of Energy Can you create an option in PVsyst to display only BABA-compliant solar products? Alternatively, can PVsyst developers monitor this list and add the BABA-compliant solar products to the PVsyst database?
  7. I just upgraded PVsyst from version 7.4 to 8.0. Can I open the PVsyst files created in version 7.4 with PVsyst version 8.0 or do I need to start from scratch?
  8. The DAE file referenced above is 276 MB so it cannot be sent via email; is there another way to get you the file? Lumion is just a 3d rendering software: Industry-Leading 3D Rendering Software | Lumion - Lumion 3D Rendering Software
  9. ok, thank you, but first the DAE file needs to be imported into PVsyst, correct? If so, could you respond to my first question: "Using Lumion we generated DAE file and tried to import it into PVsyst, but couldn't do so due to the DAE file large size. Having said that, what's the largest DAE file size compatible with PVsyst?" Who can resolve this issue?
  10. Greetings everyone, We are designing a bus parking garage in Revit 2024 and would like to specify PV panels on the roof. Using Lumion we generated DAE file and tried to import it into PVsyst, but couldn't do so due to the DAE file large size. Having said that, what's the largest DAE file size compatible with PVsyst? The second question is about the best workflow for PV system design in PVsyst: Should PV cells be placed on the roof in Revit, Lumion or PVsyst?
