rock_fire07
Everything posted by rock_fire07
  1. Thank you for your response. The problem persists even when I move to the next page and select the default value. Regards.
  2. Hello everyone, When I enter the parameters for a self-consumption system with storage, an error appears that says: 'Inverter Definition: The output nominal power is not defined for a Sungrow battery with AC coupling.' I don't know what parameters I need to enter or where this parameter is located. Thanks in advance
  3. Hello. There is a problem with the configuration of the bifacial model when working with two different orientations. In the first orientation, I can modify any parameter, and the graphs update accordingly. However, when I change parameters for the second orientation, such as the height above ground, the graphs and representations do not update. For example, I set the height above ground to 1.2 m, but in the representation, it remains at 2 m. Best regards.
