FredrikRH
  1. Is there any more knowledge on this topic as of now? Will the flickering from the wind turbine be accounted for at all in PVsyst and is an approach to simulate the turbine as a disc and not with the blades? I expect this would be a conservative approach.
  2. I have sent the project now, not sure where the error lies but it does not appear to be too big of a difference in total specific production between the two projects as it would seem from the detailed losses diagram.
  3. Hello, I tried using version 8 with a bifacial system in multiple orientations. When I simulated it apparently only calculated the Global incident on ground for bifacial gain on my first orientation (see attached figure). In this case this sub-array was only 0.68 MWp compared to the full system of 28.76 MWp so the reduction in bifacial side production was quite noticeable. Is version 8 supposed to calculate bifacial gain for all orientations or will it only calculate for the first defined orientation?
