Carlos Melim
  1. Good morning, everybody. I have a PV System with 100 un 550W modules but with two orientations: 1 string with 20 modules, orientation 1 (20 modules) 4 strings with 20 modules, orientation 2 (80 modules) The 5 strings are divided in three arrays: Sub-array 2 with orientation 1: PV Array and Sub-array 1 with orientation 2: For I have two orientations, I want to use the multi-MPPT and Power Sharing features. I have 5 strings but I can find only 4 or 6 MPPTs inverters. Assuming I choose a 40 kW 4 MPPTs inverter: If I connect the 5 strings to 3 MPPTs inputs the Power Sharing feature will not work. The inverter MPPT inputs are not complete. If I connect the 5 strings to 4 MPPTs inputs the Power Sharing feature will not work. The inverter doesn´t have enough MPPT inputs. Assuming I choose a 60 kW 6 MPPTs inverter: If I connect the 5 strings to 5 MPPTs inputs the Power Sharing feature will not work. The inverter MPPT inputs are not complete. If I arrange the the 80 modules orientation 2, in 5 strings to complete the 6 inverter MPPT inputs, Pnom ratio will be too low. What am I missing? Any help will be greatly appreciated. I am looking forward to hearing from you. Best regards Carlos Melim
