Hello,
	I want to identify near shading using the simulation output parameters in an 8760.
	I have seen the column FShdBm used for this purpose. What does this parameter actually define? I see the definition on the PVsyst page but the referenced parameters in the definition are not defined (FShdBmNear shading factor on beam = BeamShd / BeamHrz). What does BeamShd and BeamHrz mean here?
	How would one utilize this FShdBm to determine near shading? If this ratio falls below 1 then near shading is present? Or is this too strict and a more realistic way to use this parameter is to define when this ratio falls below 0.98(?) then near shading is present?
	If FShdBm is not the best 8760 parameter to use to determine near shading, what other parameter is recommended for this purpose?
	Thank you for any help.
