Pete
Everything posted by Pete
  1. I fully expected energy to plateau as you mention dtarin. Perhaps my variant comparison above was confusing- so I have added some annotations below to help better explain my concern. At 50M, there should be very minimal row-row shading with of course the exception in the early / late parts of the day. To your point, we should not see an appreciable yearly energy increase. This "plateau does not occur until roughly 50m. @Michele Oliosi I did add the suggested shading loss to the 8760 data and plotted in excel. I do not see a significant change here. I can share my model - can you suggest a method for file sharing?
  2. Background: I built a simple single inverter model to investigate energy vs tracker row spacing. In all cases, I kept the array consistent and only increased the tracker spacing in increments of 0.25M. I expected to see that annual energy would plateau at some point and not increase, indicating the MAX optimum space. There is more to my analysis but, this is the background for the issue at hand. As I increased from 6 through 8.5 meters, energy continued to increase. I then jumped to 50 meters and the trend continued! Similarly, I used 100M and the results continued to climb. I have no HV transformer or other losses and the consistent system definition below:
  3. I find myself needing to compare two independent models for project proposal evaluation. Often times, one author of a particular model may wish to skew results for one purpose or another. Today, I caught a change on MV transformer copper loss that was used to bias the results of the simulation. At present moment, I find myself comparing each design parameter by manually reviewing each model / variant and cataloging this data into a spreadsheet. I would very much like to export all of the configuration variables for a particular variant. By this, I mean every selection that the user selects or configures in both the main and optional parameters. I could quickly then compare various models / variants against one another. Does this functionality exist? Is there a technique to achieve my goal? Thank You! Pete
  4. Hello- and thanks in advance for your thoughts! I work for a major utility, who is implementing large, medium and small scale solar. My first engineering project involves a 7MW site that has been issued for bid amongst several local firms. I've received their PVSyst reports and models, now I am in the process of comparing one against the other. My process for evaluation is as follows: For each proposal, I reviewed the PVSyst simulation report and catalog all of the variables that the modeler used for the simulation. I then compared each vendor against the others as shown in the attached file, to help notice where vendors for example didn't include losses. I'm learning that firms "accidentally" do not include losses to make their proposal more favorable for example. Is there any method to export all of the selected & defined parameters in a model / variant? I would like to export all input variables of a variant and not the energy simulation results. I would like to do this for all models to better understand differences between models, to identify is something is missed etc. Lastly, if my approach is flawed or there is a better technique, please advise. I had a brief period of time for my analysis and am open to thought or suggestion! Best, Pete Sample PVsyst analysis.pdf
