Hi ! I'm also doing a simulation with bifacial vertical PV and I'd like to know to what extend PVsyst is accurate. From what I understand : soiling, far shading and near shading from the 3D scene are not considered for the back face thus the production is overestimated. Also, if the nominal energy is not accurate, then most of the other following losses will also be wrong (inverter behavior, ohmic losses, grid limitation, etc.). Are you confident with your results ? Or are you planning on improving the calculation ?
	Many thanks
