jeffgeter
  1. uno online It is possible to simulate modules with a 45-degree orientation in PVsyst. In the module definition, you can set the tilt angle to 45 degrees and the azimuth angle to 0 degrees. This will simulate the modules as if they are oriented on their point. In the module layout, you can use the “Manual” option to place the modules in the desired orientation. You can also use the “Shading Scene” to adjust the shading of the modules based on their orientation.
