AlvaroRuiz
Good morning; I have a question, is it possible in PVSYST to obtain the graphed surface of the shadow that an object generates throughout the day on a surface? (it doesn't matter what it is) The objective is to obtain this area to be able to export it to Autcad and have the footprint of this daily shadow. Tools like PVCase do allow you to obtain this shadow area but I don't know if it is possible in PVsyst.
Good morning again; The value of 5300 MVA is referred to the STC of the MV transformers so it is not necessary a change to STC because they are already the conditions included in the data sheet. What configuration should I choose to maintain these values of 5.3 MVA in STC? Thank you very much for your help.
Good morning I would like some output variable in Btachsimulation that allows to know the CGR of the plant with different simulation Pitch. The objective is to see how the CGR varies with different simulation Pitch. Thank you very much again to all the PVSyst team.
Diferencia Producciones entre Informe y Excel Bachsimulation.
AlvaroRuiz replied to AlvaroRuiz's topic in Simulations
Good afternoon; I attach another simulation example with the EArray variable included. The simulation is done for year 1. The variables GlobHor, T_amb, GlobInc and GolbEff and PR match but the variables E_Grid and EArray do not. If you need more data, please let me know. Thank you very much. -
Good afternoon again Michele, thank you for your prompt response. Is this inverter clipping a parameter reflected in the .OND of the inverter or is it a modifiable element under some type of internal PVSyst standard? If it were an internal parameter and you would like to know where it can be modified. Thank you very much again.
Hello Michelle, it's a pleasure to meet you. I have this box checked as seen in the simulation. I have also tried to simulate on an hourly basis and the annual production coincides with the sum of hourly production, so the problem seems to be between Excel calculation and the data in the reports. -
Buenos días; Tras ejecutar varias simulaciones de un determinado proyecto me encuentro que en varias de las simulaciones hay una diferencia de E_grid entre informe y las Batchsimulation. En simulación por defecto tengo el año 1 , Pitch 6,5 metros justo los mismos parámetros que incluyo en Excel BatchParams para las mismas condiciones. Adjunto fotos correspondientes a la misma variable de simulación y sin variar ningún dato. No entiendo el por que de esta diferencia entre informe y Batchsimulation, por favor si alguien me puede ayudar se agradecería. Un saludo a toda comunidad.
AlvaroRuiz started following Joao Branco
Buenas tardes, Cuándo trato de realizar una comparativa de producción a la salida de sistema con dos configuraciones, obtenga las siguientes tablas. Inversor central FS4200K a 4200 MVA Inversor de 330MVA No acabo de entender como la entrega de potencia en el caso del inversor central sea tan en una fase tan final y como la del inversor String tiene una tendencia mas progresiva si bien el orden de magnitud por tamaño del inversor es completamente diferente, ¿alguien me ¿Puede explicar esta duda? Muchas gracias de antemano.
