Michalis Angeli
Import file from rhino8 to pvsyst
Michalis Angeli replied to Michalis Angeli's topic in Shadings and tracking
Hello Stephane, I had tried all that you suggested me, but I still encounterinng the same problem. May I should change something related to parametrs in the picture below? Also, i had chosen portrait for the module orientaition but in 3d schene panels appear in landscape orientation. Have you any idea how to find a solution about this? -
Hello Stephaene, Yes, your instruction works perfect. Furthermore, I would like to ask if I should change anything else in order PVsyst recognize the correct azimuth. When i don't choose the choice "Apply 180 rotation". Because in image that i attach below i defined from 3d schene dialog Azimuth 0 degrees. But the one panel cover the other. By default in this system PVsyst defined the azimuth -90 degrees, which i don't want in my simulation because changes the results. (second image) Thank you. -
Hello, I am trying to add a drawing from rhino to Pvsyst. I import the file with name .3ds in 3d scene. However I have a couple of questionos. First of all, after I defined the tilt of panel, for example 25 degrees, I ran shading animation but I didn't receive results and i can't calculate the shading table. Should I change something in import result dialog that is depicted in image2? Thank you
Hello, I would like to ask something about 3d schene and azimuth of pv panels. In one project in which i am working this period, I have a house + 2-sided roof. The plane tilt and azimuth is 25 & 30 degrees, as you can see in first pic1. Therefore, when I draw the house in 3d shene in order to achive that azimuth i define it -64 degress. (pic2) Then i draw the panels with tilt 25 degrres and azimuth 30 degrees, like i defined in Orientation window. (pic3) So, my question is this; The azimuth which pvsyst takes into account to calculate the shadings and production is the 30 degrees that i defined in orientation? And why the azimuth of house is different than the azimuth of panels, since both "face" the sun position from the same position. Thank you in adnance. Sincerely,
Hello, I did that you had said to me and I managed to import my csv file. Therefore, I face a problem right now. I have a consumption profile with annual consumption 65.2 kWh/yr. We can't materialize a bigger pv system from 40 kW. So we are going to build a pv system 38.8 kW, with a yearly production approx 51.3 Mwh/yr This project is such different because of two parameters, that I will explain below: 1. The production from pv system can't cover the whole consumption. 2. There is a limit in gird that forbids to consumer to inject the excess power to grid, when the consumption is lower than production. Therefore, I had calculated the yearly excess energy. This energy is the different between the energy that consumpted directly the time produced. So, I will need a storage system 20kWh. When I define this data in pvsyst i face some problems. I attach some pictures to be more clerarly the error. I would like to learn the limits in Battery input charge and Inverter battery to user's consumption. Thank you!
Hello, I want to define self consumption adding a csv file for load profile (hourly consumption). The templates are only per 15 minutes. I would like to ask if there is a template for load CSV file, with range 1 hour and not 15 minutes. Or if there is an empty template to full it, by me. Thank you.
Hello again! I am trying to develop a project with 3 differents orientations. And I face that problem. "The inverter is strongly undersized". However, when I select strings configuration I face another problem, as you can see in picture below. This is problem is due to that i don't use optimizer for this orientation that presented the subarray 3?
Very well, now is clear! Thank you very much!
Very well, so with phrase "Mixed orientations can only put different orientation in parallel, not in series" you mean that i can't have a big string in one MPPT with pv modules equal to addition of panels from two orientations. But i can have two seperates strings for each orientation? In this diagramm, I have 4 different orientations, so i have 4 seperates strings. Each inverter have 1 string in each MPPT input. When i try to define the mixed orientation that error appeare. So what is my fault? Maybe I don't understand somethin well enough to forward.
I have tried that you describe above and works. But i face other i can't define only 3 panels in one string to Inverter. That i want to say, is I am trying to connect pv modules with east orientation with south orientation in the same string in the same MPPT. However this isn't acceptable from PVSYST while i have two differents orientations i should do seperates subbarrays. For this reason I had tried to mixe the orientations.
Very well thank you very much. May that in future solved?
Thank for your answer. Have a nice day!
Hello, I would like to ask if there is the opportunity to Mixed more than 2 orientations. specifically, i have a project with 4 several orientations. However, while I am trying to define the system I see omly the option Mixed #1 and #2. As you can see in pictuer i attach below. is there the option to choose Mixed orientation #3 and #4 ? Or mixed orientation #1 and #3 for example?? Thank you!
Hello and happy new year! I am trying to attribute some pv panels in a string. And i recieve that Warning "the selected belongs to an array of orientation#1. It cannot be attributed to this tablem of orientation#2". My project has 4 several orientations. During system's definition, I choosed orientation mixed #1 and #2. The rest orientations had taken into account as seperates. How can I solve that error? I attach some screenshot about my project and warnings.
Thank you very much.
