abcpvpv
Everything posted by abcpvpv
  1. I've been emailing you for 1 month now. Have you found the reason?
  2. SketchUp is paid software,You need to spend money to buy it。 is there any free software that can replace it?
  3. i have sent them to support@pvsyst.com
  4. in dwg ,I have set the material for the pv faces. dwg -->fbx Autodesk FBX converter , fbx--> DAE in pvsyst , import DAE , there is no material. after importing DAE. the "Transform to PV faces" is gray . why ? what should I do. Can you give detail steps of importing dwg into pvsyst ?
  5. there are more than 4000 pv 3dface in dwg. 1 impert dwg into sketchup 2 export to dae 3 import dae into pvsyst most of the them are ok. but some of the pv 3d face is splited to two triangle. why ? if i delete 3500 face. only export 500 faces (include the wrong faces just now) to DAE. then import 500 faces into pvsyst. all of them is ok.....。they are not splitted to 2 triangle.
  6. terrain there are many CAD point (x,y,z) of the terrain. how to import them to PVSYT
  7. in cad ,x is east, y is north. in pvsty, x is west, y is south. if import cad (convert to dae ) to pvsyst, all of the pv(3d face) is rotated 180 degree. how should i do ?
