Nikoloz
Everything posted by Nikoloz
  1. Actually there is possibility but I don't want to use it. it takes too much time - editing PDF after simulation is done, but this method is uncomfortable .
  2. Hello I have problems with module layout with Astro energy PV modules. No problems with other brands with same orientation and location , mostly we are using JA solar modules. I don't understand what is wrong with it please see attached screen
  3. Hello is it possible to make our company logo size as big as PVsyst logo size ? I could not find any option for this ..It seems frivolous that in the simulation report, PVsyst logo visible on one side , and our company logo is very small on the other side. ๐Ÿ™‚ please see attached screenshot.
  4. Hello I have 1 suggestion . In PVsyst-Main parameters-system-pre-sizing help, there are only 3 options 1. No sizing 2. Planned power . 3. available modules area. (4. Number of Modules) there is very often the situation when we have to make project with exact amount of PV modules. for example 527 or any other amount . it would be much easier if there will be a 4.th option where you enter exact amount of modules . otherwise we have to count strings and modules in series separately on calculator to get that total amount of modules we want. Thank you
  5. The problem is solved. PVSyst is not guilty ๐Ÿ™‚ The problem was in old version of Inverters soft .. manually uploaded new version and its working correctly now.
  6. Hello. We have simulated in pvsyst solar plant I have used 19 modules per string itโ€™s 20 gradus Celsius Iโ€™m outside and voltage rises up to 930 volts and plant is shutting down. Is it investor problem or ?
  7. Hello i have question in PVsyst , system desighn..... Whet PVsyst shows that the inverter power is slightly undersized it allows me to make simulation. what if a leave those string an module amount the system will work or it will have some problems in future?
  8. Hello there Does anybody solve this problem ?? I have the same issue --- For example I have one project 498kWp with bifacial modules...when a make them in "Near shading" and number of modules in length 1 and in height X modules on each table with pitch 5m. it is ok no errors acquire ... but when I make 2 modules in length and X modules in height with pitch 10m the same error appears on screen...I think it is PVsyst's problem some bug mabe
