Nikoloz
  1. Hi everywone. Please tell me if it is possible on main rezults page to get yearly results -month by month with P75 figures. As default it shows P50
  2. Hello please help after simulation suddenly appeared this warning : *** Warnings during the initialization: Relative humidity is available in the weather data variables No Precipitable Water Data available. Spectral correction will use Relative Humidity to estimate Precipitable Water. I i could not find any humidity issues in Meteo data details. Such error newer appeared before
  3. thanx alot but there is still one question. where to add an inverter >???? unversal controller is not inverter. there is n otion to choose ?..
  4. Hello there. I have serious problems with bifacial computation when I have different pitches in one procets ... is this bug or I am making something wrong ?????? I have project where part of panes are located on slope which needs to have 10 m pich and other part which needs to have 15m pitch... the question is how to make it as 1 project ???? or how to seperate it to get 1 simulation figures. Pvsyst gets it as 1 orientation . PS " unlimited sheds " is not a solution. it does not work in this situation
  5. Hello is there any video tutorials for standalone systems ? what I could find is only ongrid systems. and also offgrid videos but on "hindi english" which I dont understand
  6. Actually it counts in simulation. 20 batteries.
  7. So it means that I cannt change amount of batteries as i whish. i have o tell to my customer thas don't warry this project is with bugs ?
  8. Hello I have such question . we have project with huawei SUN2000-12K-MAP0 inverter and huawei 7 kw elements, this inverter can work wth 2 powrmodules 21kw each it means 2 racks with 3 elements each. but i cannot add rackswith such amount of elements it deafolt has 1 rach with 8 elements ... how to change it?
  9. Hello is it possible to import KMZ or KML file in to 3d shading scene as a ground object? for example
  10. we will need cobiner boxes
  11. Hello I have such question. does anybody had used modular inverters ? Sungrow_SG1100UD what about this inverter ? when I uploaded OND file in PVsyst there is no information about MPPTs, there is some error with dtasheet ? I have to make desighn of 100MW plant but how to organise strings in mppts?? here is datasheet link https://en.sungrowpower.com/productDetail/4102/1-x-modular-inverter-sg1100ud-20
  12. No..... CSV file is not a solution it took an ugly terran. I have converted obj file to 3ds fil , which was 7 MB in size , imported it to 3d shading scene as a groung data but there is another big problem PVsyst is not situable to work with high quality objects (the 3d terran what PVsyst imports by default those maps are too old) and it stucked , frezzed and didnot respond.we are working with huge landskape about 1.4 square kilometers . This is a serious problem when your customers are working on big farms like 150-200 MW and if PVsyst freezes all the time
  13. Hello Does anybody know how to export terran as 3d object From DJI Terra to PVsyst?? Dji terra is an app to use with dji matrice drone
  14. Hello @Nils Lang I have the same problem with 8.0.6 version. When importing topography data. the project is 118MW huge territory. It is ok with smaller projects. s this because of PVsyst problem or because of my Video card or Ram ??? I have sent an e-mail to support@pvsyst.com with log files
