Omama Zaheen
  1. On a 660kW site, I have used both Bifacial and monofacial solar panels. 44 strings are of bifacial panels and 1 string in a separate MPPT has all monofacial panels. While running Simulation PV syst give the error that "When Defining a bifacial system, you should define a bifacial PV module in each sub-array" Why is it giving such error? I have used the monofacial panels in a different MPPT
  2. @Michele Oliosi Which means in the highlighted box I just have to enter the temp increase i.e., 5°C? and PV syst will add this 5°C while running simulations? Can you please explain the significance of using this feature in the simulation, for my better understanding.
  3. @Michele Oliosi Your above responses are very much helpful. However, I need further clarification on "External ambient temperature with Shift". What does this shift means? For instance if my external "Maximum" ambient is 40degree centigrade in Summers, what should be the Shift?
