Navid
Everything posted by Navid
  1. Since we have updated PVsyst to version 8. Unfortunately, we keep getting this error message. Can you please support us here. We export the PVC file from PVCASE. We don't always have this problem, but only with areas that have an elevation.
  2. Navid
    MeteoData
    how can I create an average of weather data. from at least 4 sources?
  3. if it would be possible to create a report in Tracker Variant how much distance the modules have to the ground in different seasons. Or is possible for each table to enter a single angle? So that adapts to the floor?
  4. Hello, I am trying besides exporting the modules, to export the terrain also as a CSV file. But unfortunately when I insert the two in PVsyst, there is a mismatch. Do you know how I can fix the problem?
  5. With what percent is the dust from a brown coal open air house calculated on a solar park.
  6. Hi, For an eastwest module orientation plan, I would like to consider the bifacial modules as well. But unfortunately you can only do it for south alignment and tracker. Do you have a solution how I can consider this in PVsyst. Thank's
  7. Perfect worked. Thank You
  8. Hello together, since we have installed the new version of PVsyst 7.3, unfortunately a problem has occurred. It is about azimuth. Although all modules are oriented to the south, because of the topography, the rows are created on 4 different orientations (as in the attachment). This is problematic for us because the result shows us that modules have a deviation. The 3D file is created by PVCASE (pvc). Please tell us a solution how to fix the problem?
