Hello, i have been having a very frustrating time trying to generate a custom csv file for our local tariff structure. The online help section all and all is not clear and varies greatly with other examples online. If some one will be kind enough the point in the right direction on how to actually setup the csv for the attached tariff structure it will be greatly apricated.
	The structure below is for non seasonal change
	Then you have the Net metering account Credit Tariff
	And the Cost of Electricity depending on your connection size, i understand that for each connection size you will need a custom csv.
	If you look at the tariff structure above, you have "energy charge" in kWh, Maximum demand in kVA, and 2 levies in kWh again. how can i setup this in a csv to that pvsyst can interpret the data correctly and calculate it correctly from kWh or kVA as needed for the tariff structure. Or should i generalize a power factor as standard through out, even though it varies greatly according to the load profile.
	Secondly, just a general question, does pvsyst take into account the effect on power factor for the injection of active power into the grid from a PV system? or is it assumed that the inverters will have dynamic power factor correction activated?
	Regards
