Hello.
The topography was drawn in the sketchup and the module angle was arranged equally at 18 degrees
When I imported the 3D file in pvsyst, the directions are defined as seven, and it says to apply subarray for each direction.
It's hard to tell them to configure the same array with different arrays.
How do I solve this?
Orientation parameters
Field type: Several orientations
4 orientations: Tilt/azim = 18°/6°, 18°/12°, 19°/14°, 18°/2°
Compatibility between System and Shadings
Orientation #1 tilt/azim = 18° / 6°
1 sub-array PNom = 1657 kWp, modules area = 7853 m²
shading 3D fields 189 tables, : , total rough area , . 7816 m²
Orientation #2 tilt/azim = 18° / 12°
1 sub-array PNom = 183 kWp, modules area = 868 m²
shading 3D fields 20 tables, : , total rough area , . 819 m²
Orientation #2: The modules area defined in the 3D scene is slightly lower than the modules area defined in the system.
Orientation #3 tilt/azim = 19° / 14°
1 sub-array PNom = 17 kWp, modules area = 83 m²
shading 3D fields 2 tables, : , total rough area , . 83 m²
Orientation #4 tilt/azim = 18° / 2°
1 sub-array PNom = 130 kWp, modules area = 615 m²
shading 3D fields 16 tables, : , total rough area , . 657 m²
System parameters
4 sub-arrays defined
Sub-array #1 하위 어레이 #1
Orientation #1 Tilt/Azimuth = 18.1° / 6.2°
PV modules: 190 strings of 16 modules in series, 3040 total
Pnom = 545 Wp Pnom array = 1657 kWp, Area = 7853 m²
Inverters (60.0 kWac) 1 MPPT inputs, Total 1320 k
Sub-array #2 하위 어레이 #2
Orientation #2 Tilt/Azimuth = 18.4° / 12.4°
PV modules: 21 strings of 16 modules in series, 336 total
Pnom = 545 Wp Pnom array = 183 kWp, Area = 868 m²
Inverters (60.0 kWac) 1 MPPT inputs, Total 180 kW
The array area exceeds the specified maximum available area.
Sub-array #3 하위 어레이 #3
Orientation #3 Tilt/Azimuth = 18.6° / 14.3°
PV modules: 2 strings of 16 modules in series, 32 total
Pnom = 545 Wp Pnom array = 17 kWp, Area = 83 m²
Inverters (60.0 kWac) 1 MPPT inputs, Total 60 kWa
The inverter power is strongly oversized.
Sub-array #4 하위 어레이 #4
Orientation #4 Tilt/Azimuth = 18.0° / 1.7°
PV modules: 14 strings of 17 modules in series, 238 total
Pnom = 545 Wp Pnom array = 130 kWp, Area = 615 m²
Inverters (60.0 kWac) 1 MPPT inputs, Total 120 kW
3D shadings parameter
227 fields defined Total area 9376 m²
Field #1: table 9X2_5, face #1
Total area = 47.0 m²
Orientation #1 Tilt/Azimuth = 18.1° / 6.4°
Field #2: table 9X2_4, face #1
Orientation #2 Tilt/Azimuth = 18.3° / 10.0°
Field #3: table 9X2_3, face #1
Field #4: table 9X2_2, face #1
Orientation #1 Tilt/Azimuth = 18.2° / 7.6°
Field #5: table 9X2_1, face #1
Orientation #1 Tilt/Azimuth = 18.1° / 6.7°
Field #6: table 8X2_99, face #1
Total area = 41.7 m²
Field #7: table 8X2_98, face #1
Field #8: table 8X2_97, face #1
Orientation #1 Tilt/Azimuth = 18.1° / 4.6°
Field #9: table 8X2_96, face #1
Orientation #1 Tilt/Azimuth = 18.1° / 4.3°
Field #10: table 8X2_95, face #1
Orientation #1 Tilt/Azimuth = 18.1° / 4.9°
Field #11: table 8X2_94, face #1
Field #12: table 8X2_93, face #1
Orientation #3 Tilt/Azimuth = 18.6° / 14.4°
Field #13: table 8X2_92, face #1
Orientation #1 Tilt/Azimuth = 18.1° / 5.5°
Field #14: table 8X2_91, face #1
Orientation #1 Tilt/Azimuth = 18.1° / 7.0°
Field #15: table 8X2_90, face #1
Field #16: table 8X2_9, face #1
Orientation #1 Tilt/Azimuth = 18.1° / 6.1°
Field #17: table 8X2_89, face #1
Field #18: table 8X2_88, face #1
Field #19: table 8X2_87, face #1
Orientation #1 Tilt/Azimuth = 18.2° / 7.3°
Field #20: table 8X2_86, face #1
Field #21: table 8X2_85, face #1
Field #22: table 8X2_84, face #1
Field #23: table 8X2_83, face #1
Field #24: table 8X2_82, face #1
Field #25: table 8X2_81, face #1
Orientation #1 Tilt/Azimuth = 18.1° / 5.8°
Field #26: table 8X2_80, face #1
Field #27: table 8X2_8, face #1
Orientation #4 Tilt/Azimuth = 18.0° / 0.0°
Field #28: table 8X2_79, face #1
Orientation #2 Tilt/Azimuth = 18.5° / 12.7°
Field #29: table 8X2_78, face #1
Field #30: table 8X2_77, face #1
Field #31: table 8X2_76, face #1
Field #32: table 8X2_75, face #1
Field #33: table 8X2_74, face #1
Orientation #4 Tilt/Azimuth = 18.0° / 1.8°
Field #34: table 8X2_73, face #1
Field #35: table 8X2_72, face #1
Field #36: table 8X2_71, face #1
Orientation #1 Tilt/Azimuth = 18.0° / 4.0°
Field #37: table 8X2_70, face #1
Field #38: table 8X2_7, face #1
Field #39: table 8X2_69, face #1
Field #40: table 8X2_68, face #1
Field #41: table 8X2_67, face #1
Field #42: table 8X2_66, face #1
Field #43: table 8X2_65, face #1
Field #44: table 8X2_64, face #1
Field #45: table 8X2_63, face #1
Field #46: table 8X2_62, face #1
Field #47: table 8X2_61, face #1
Orientation #4 Tilt/Azimuth = 18.0° / 2.2°
Field #48: table 8X2_60, face #1
Field #49: table 8X2_6, face #1
Field #50: table 8X2_59, face #1
Field #51: table 8X2_58, face #1
Field #52: table 8X2_57, face #1
Orientation #4 Tilt/Azimuth = 18.0° / 2.5°
Field #53: table 8X2_56, face #1
Field #54: table 8X2_55, face #1
Field #55: table 8X2_54, face #1
Field #56: table 8X2_53, face #1
Field #57: table 8X2_52, face #1
Field #58: table 8X2_51, face #1
Field #59: table 8X2_50, face #1
Field #60: table 8X2_5, face #1
Field #61: table 8X2_49, face #1
Field #62: table 8X2_48, face #1
Field #63: table 8X2_47, face #1
Field #64: table 8X2_46, face #1
Field #65: table 8X2_45, face #1
Field #66: table 8X2_44, face #1
Field #67: table 8X2_43, face #1
Field #68: table 8X2_42, face #1
Field #69: table 8X2_41, face #1
Field #70: table 8X2_40, face #1
Field #71: table 8X2_4, face #1
Field #72: table 8X2_39, face #1
Field #73: table 8X2_38, face #1
Field #74: table 8X2_37, face #1
Orientation #2 Tilt/Azimuth = 18.4° / 11.5°
Field #75: table 8X2_36, face #1
Field #76: table 8X2_35, face #1
Field #77: table 8X2_34, face #1
Field #78: table 8X2_33, face #1
Field #79: table 8X2_32, face #1
Field #80: table 8X2_31, face #1
Field #81: table 8X2_30, face #1
Field #82: table 8X2_3, face #1
Field #83: table 8X2_29, face #1
Field #84: table 8X2_28, face #1
Field #85: table 8X2_27, face #1
Field #86: table 8X2_26, face #1
Field #87: table 8X2_25, face #1
Field #88: table 8X2_24, face #1
Field #89: table 8X2_23, face #1
Field #90: table 8X2_22, face #1
Field #91: table 8X2_21, face #1
Field #92: table 8X2_208, face #1
Field #93: table 8X2_207, face #1
Field #94: table 8X2_206, face #1
Field #95: table 8X2_205, face #1
Field #96: table 8X2_204, face #1
Field #97: table 8X2_203, face #1
Field #98: table 8X2_202, face #1
Field #99: table 8X2_201, face #1
Field #100: table 8X2_200, face #1
Field #101: table 8X2_20, face #1
Field #102: table 8X2_2, face #1
Field #103: table 8X2_199, face #1
Field #104: table 8X2_198, face #1
Field #105: table 8X2_197, face #1
Field #106: table 8X2_196, face #1
Field #107: table 8X2_195, face #1
Field #108: table 8X2_194, face #1
Field #109: table 8X2_193, face #1
Orientation #3 Tilt/Azimuth = 18.6° / 14.2°
Field #110: table 8X2_192, face #1
Field #111: table 8X2_191, face #1
Field #112: table 8X2_190, face #1
Field #113: table 8X2_19, face #1
Field #114: table 8X2_189, face #1
Orientation #4 Tilt/Azimuth = 18.0° / 3.1°
Field #115: table 8X2_188, face #1
Field #116: table 8X2_187, face #1
Field #117: table 8X2_186, face #1
Field #118: table 8X2_185, face #1
Field #119: table 8X2_184, face #1
Field #120: table 8X2_183, face #1
Field #121: table 8X2_182, face #1
Field #122: table 8X2_181, face #1
Field #123: table 8X2_180, face #1
Field #124: table 8X2_18, face #1
Field #125: table 8X2_179, face #1
Field #126: table 8X2_178, face #1
Field #127: table 8X2_177, face #1
Field #128: table 8X2_176, face #1
Field #129: table 8X2_175, face #1
Field #130: table 8X2_174, face #1
Field #131: table 8X2_173, face #1
Field #132: table 8X2_172, face #1
Field #133: table 8X2_171, face #1
Field #134: table 8X2_170, face #1
Field #135: table 8X2_17, face #1
Field #136: table 8X2_169, face #1
Field #137: table 8X2_168, face #1
Orientation #1 Tilt/Azimuth = 18.0° / 3.7°
Field #138: table 8X2_167, face #1
Field #139: table 8X2_166, face #1
Field #140: table 8X2_165, face #1
Orientation #1 Tilt/Azimuth = 18.0° / 3.4°
Field #141: table 8X2_164, face #1
Field #142: table 8X2_163, face #1
Field #143: table 8X2_162, face #1
Field #144: table 8X2_161, face #1
Field #145: table 8X2_160, face #1
Field #146: table 8X2_16, face #1
Orientation #1 Tilt/Azimuth = 18.1° / 5.2°
Field #147: table 8X2_159, face #1
Field #148: table 8X2_158, face #1
Field #149: table 8X2_157, face #1
Field #150: table 8X2_156, face #1
Field #151: table 8X2_155, face #1
Field #152: table 8X2_154, face #1
Field #153: table 8X2_153, face #1
Field #154: table 8X2_152, face #1
Field #155: table 8X2_151, face #1
Field #156: table 8X2_150, face #1
Field #157: table 8X2_15, face #1
Field #158: table 8X2_149, face #1
Field #159: table 8X2_148, face #1
Field #160: table 8X2_147, face #1
Field #161: table 8X2_146, face #1
Orientation #4 Tilt/Azimuth = 18.0° / 2.8°
Field #162: table 8X2_145, face #1
Field #163: table 8X2_144, face #1
Field #164: table 8X2_143, face #1
Field #165: table 8X2_142, face #1
Field #166: table 8X2_141, face #1
Field #167: table 8X2_140, face #1
Field #168: table 8X2_14, face #1
Field #169: table 8X2_139, face #1
Field #170: table 8X2_138, face #1
Field #171: table 8X2_137, face #1
Field #172: table 8X2_136, face #1
Field #173: table 8X2_135, face #1
Field #174: table 8X2_134, face #1
Field #175: table 8X2_133, face #1
Field #176: table 8X2_132, face #1
Field #177: table 8X2_131, face #1
Field #178: table 8X2_130, face #1
Field #179: table 8X2_13, face #1
Field #180: table 8X2_129, face #1
Field #181: table 8X2_128, face #1
Field #182: table 8X2_127, face #1
Field #183: table 8X2_126, face #1
Field #184: table 8X2_125, face #1
Field #185: table 8X2_124, face #1
Field #186: table 8X2_123, face #1
Field #187: table 8X2_122, face #1
Field #188: table 8X2_121, face #1
Field #189: table 8X2_120, face #1
Field #190: table 8X2_12, face #1
Orientation #2 Tilt/Azimuth = 18.4° / 11.2°
Field #191: table 8X2_119, face #1
Field #192: table 8X2_118, face #1
Field #193: table 8X2_117, face #1
Field #194: table 8X2_116, face #1
Field #195: table 8X2_115, face #1
Field #196: table 8X2_114, face #1
Field #197: table 8X2_113, face #1
Field #198: table 8X2_112, face #1
Field #199: table 8X2_111, face #1
Field #200: table 8X2_110, face #1
Field #201: table 8X2_11, face #1
Field #202: table 8X2_109, face #1
Field #203: table 8X2_108, face #1
Field #204: table 8X2_107, face #1
Field #205: table 8X2_106, face #1
Field #206: table 8X2_105, face #1
Field #207: table 8X2_104, face #1
Field #208: table 8X2_103, face #1
Field #209: table 8X2_102, face #1
Field #210: table 8X2_101, face #1
Field #211: table 8X2_100, face #1
Field #212: table 8X2_10, face #1
Field #213: table 8X2_1, face #1
Field #214: table 7X2_7, face #1
Total area = 36.5 m²
Field #215: table 7X2_6, face #1
Field #216: table 7X2_5, face #1
Field #217: table 7X2_4, face #1
Field #218: table 7X2_3, face #1
Field #219: table 7X2_2, face #1
Field #220: table 7X2_1, face #1
Field #221: table 6X2_4, face #1
Total area = 31.3 m²
Field #222: table 6X2_3, face #1
Field #223: table 6X2_2, face #1
Field #224: table 6X2_1, face #1
Field #225: table 5X2_3, face #1
Total area = 26.1 m²
Field #226: table 5X2_2, face #1
Field #227: table 5X2_1, face #1
Orientation #1 189 tables, Area = 7816 m²
Orientation #2 20 tables, Area = 819.2 m²
Orientation #3 2 tables, Area = 83.48 m²
Orientation #4 16 tables, Area = 657.4 m²
신규 시뮬레이션 변형
List of other shading objects
Obstacle #-227 Mesh02
Obstacle #-227 Mesh01
Use in simulation: Linear shadings (Irradiance deficit)
