gpuy
Everything posted by gpuy
Thanks André. I would like to know if: Do you have any model verification for the Ground reflection on front side? Is it possible to neglect the Ground reflection on front side during a simulation?
Hi, I was wondering why with monofacial modules, although the Ground reflection on front side is neglected, the Global incident in coll. plane depends on the albedo coefficient. I've read what states here about the albedo Physical models used > Irradiation models > Transposition model (pvsyst.com) , but I don't get which is the difference between these 2 albedo contributions. Regards, Guillermo
Electrical loss according to string - Tracking systems
gpuy replied to gpuy's topic in Shadings and tracking
Thank you for your support, Michele. Since recomputing the shading factor tables didn´t change anything, I´would like to send you the project. Shall I do that via email?- 8 replies
- backtracking
- near shadings
- (and 3 more)
Thank you for your answer Michele. I´ve checked the ShdBLss (Loss on the beam component), ShdDLss (Loss on the diffuse component), and ShdALss (Loss on the albedo component). They represent the next porcentage of the total shading loss: ShdBLss: 20% ShdDLss: 38% ShdALss: 42% Since ShdBLss > 0, is it still normal to have electrical losses according to strings of 0%?- 8 replies
- backtracking
- near shadings
- (and 3 more)
I would like to know if there is a reason for not obtaining "electrical loss acc. to string" when using a Horizontal Tracking System and simulating as "According to Module Strings", regardless of the "fraction for electrical effect". With fixed structures, there is "electrical loss acc. to string" when simulating as "According to Module Strings", since shadows generate mismatch of electrical response of the modules in series and strings in parallel. I was expecting the same for Horizontal Tracking Systems (despite backtracking) since once there are shadows ("near shadings: irradiance loss" is not 0), the mismatch of electrical response of the modules would cause a loss.
- 8 replies
- backtracking
- near shadings
- (and 3 more)
PV loss due to irradiance level changes when changing the module degradation loss
gpuy replied to gpuy's topic in Simulations
I´ve realised the problem happens only with PAN files provided by manufacturers (no default checkboxes checked), and it doesn´t happen with PAN files from the database. Thank you very much for your support, Michele. Regards, Guillermo. -
Thanks for your answer. How could I check if the module I´m using has standard one-diode parameters? -
Sorry, I attached screenshots from 2 different projects. But I assure you that´s not the problem as you will see: -
With certain modules, the PV loss due to irradiance level changes when changing the module degradation loss. This only happens when the module degradation loss is changed from 0% to 0.4% but it doesn´t happen for changes from 0.4% to bigger values. But since the PV loss due to irradiance level stands for the low module efficiency with low irradiances... shouldn´t it remain constant?
