emaia121
  1. Hi, We use plenty of dual-row trackers in our plants (i.e. Array STI H250, Soltec SFONE, PVH Axone Duo etc), but configuring the 3D scene to take this into consideration doesn't seem to be possible; each row would count as a separate tracker and it messes a bit with the backtracking calculations and also with the report (each dual-row tracker counts as two trackers in the report). So I'd like to ask : 1. Is there a way to set the model to count every two adjacent trackers as a single dual-row tracker? 2. Is there a way to import a shading scene from DAE with this already built-in? Thanks
  2. Hi, I would like to know if there's any way to make PVSyst skip the checking of all variant parameters for every single click of a button in the program, i.e. only check the variant parameters and files before the simulation. In the case of very large shading scenes (say, a complex utility-scale ground-mounted system), PVSyst re-checks such shading scene for everything you do in the software (even clicking the exit button) and setting up anything can take up hours or even days. Thank you!
