Ronald
Everything posted by Ronald
  1. Thank you. I see this
  2. Question: Why is that my energy output is going above the AC capacity at certain hours of the day in Jan, Dec, Nov? DC: 96.85MWp AC: 91.47MW
  3. Dear Lazare, Thanks for your answer. is that mean, these modules will perform badly at low light (200W/m2) i.e., late evening or night?
  4. Hi, I added a PAN file that I received from a manufacturer into the PVsyst database. When I look into parameters by clicking on 'open', I see below window. I am curious to understand what does the BLUE text implies? Why it is not showing for any other manufacture's' modules?
  5. Hi Michele, Thank you for your help. Ronald
  6. Hi, I have downloaded weather files from \climatewebsite\WMO_Region_5_Southwest_Pacific\MYS_Malaysia (onebuilding.org). Which consist of zip file with epw, wea, .pvsyst, etc weather files. Can someone help or tell me how do I read EPW or PVsyst file?
  7. Hi, @michele Oliosi, Thanks for the answer. Yes, this was the problem/reason.
  8. Mail failed.
  9. Hi @Lazare Fesnien, I have mailed it, please confirm if you have received it.
  10. @Michele Oliosi Thanks for your reply. Yes, I was able to do it. However, I see that some hours there is no 'generation' even though we have GHI.
  11. It has been observed that there are specific hours of the year when PVsyst does not generate energy despite the presence of GHI values.
  12. Hi Thanks, but When I select bifacial tracking, pvsyst will not allow me to draw the layout right?
  13. Hi all, I want to export hourly energy generation, either MWh or MW, for all hours of the day in a year. I appreciate any help you can provide. Ronald R
  14. Hi, Pvsyst gives total module area based on number of modules. is there way to estimated total land area occupied by the PV plant?. Inclucing inter_row spacing area+module projected area?.
  15. Hi, How do we size a system with higher DC to AC ratio (say 1.5). I have seen in some PVsyst reports by solar PV developers, they use higher DC to AC ratio. This is for maximum revenue generation. I want to learn sizing my system with higher DC to AC ratio Thank you in advance for your help.
