Hello,
I'm actually working on a project that uses solaredge inverter. I'm creating subfield with se66 unit and se82.8 unit, with each 2 or 3 strings. The problem occurs when i add the second unit of the se66k... the "string configuration" menu doesn't recognioze the second unit of the se66k, which is created in a separated subfield. With that problem, i can't run any simulation, because all the strings are put into the first unit of the se66k, instead of being 2 each unit. The unit is therefore overpowered in entry. The second probleme i have is that it create a problem with the surfaces and orientations with the 3d model. I drew a 3d model with the PVsyst "shading" tool, but the areas per orientation don't match the system configuration (altough the orientations in the subfield are always mixed 1 and 2), which seems to be a consequence of the problem with the inverters...
Can someone help me? the images are here
Thank you very much,
Pierre-Vincent
