Bruno Lima
  1. Hello Michele, Thanks for the return. I´m trying to simulate on a fixed tilt, defined 7 orientations, but I´m not being able to attach them all to the same inverter (in order to calculate the mismatch). From other forum posts, I saw that I should use the Mixed #1 and #2 to that, but in this case it will only select two different orientations? The difference in the tilt is varying from 3° to -3°, so maybe If I use these two values I´ll be calculating the worst case scenario? Thanks
  2. Hello, We are doing a project where the trackers in the field are having small discrepancies in the axis tilt (varying from -3.3º to +3º). Since they will all be conected on a single MPPT, our client asked us to calculate the mismatch loss that this will cause. Is it possible to do so in PVSyst? I tried to, but only saw the possibility of having one orientation for trackers (unlike in fixed tilt where i can have several orientations). Thanks
