asb
Everything posted by asb
  1. When generating a csv output file for "energy injected into grid" the csv file seems to contain wrong values at night time hours (for example: based on selected transformers the no-load losses at 01:00h should be around 38kW [-38.267kW]. However, the corresponding cell shows a value of -38267kW). Could this be an interface problem between PVsyst and the German version of Excel which uses comma instead of point for decimal separation? If so, is there an option to avoid this?
  2. The output file in CSV format generates values with decimal point "." (12.5). If I want to use these values of the output file in a German version of Excel I get problems because there, the decimal point is used as "," (12,5). Is there any chance to create an output file which is compatible with Excel in the German Version?
