Scrchd
  1. Thank you very much. First solution worked :)
  2. Hello, I have a problem with the simulation report in PVsyst. Everytime I try to generate one, I get this message: "File not found or could not be opened". It is worth noting that I didn't get this message on older versions, only when I updated to 7.2.12. I've tried switching workplaces and re-installing PVsyst, but it did not work. Thanks in advance for any help! Have a nice day! Pop-up
  3. Thanks, problem solved!
  4. Thank you very much! Just one more question, do you know maybe if the fact that PVsyst recognises system kind as tables on a building instead of ground-mounted impact the simulation results in anyway ? Or is it purely informative ?
  5. Hello, I have a problem with PVsyst regarding the 'system kind' shown in 'results overview' section and later on the report. To be specific PVsyst defines my system as a "Tables on a building" when in reality it's ground-mounted system. What factors are considered when defining a system kind and How can I change it ? Screenshots of shading scene and results overview in attachments. Thanks in advance. EDIT: The shading scene was created with Sketchup and imported to PVsyst Shading scene Results overview
