solarDG1470
  1. Hi, our team often get blank reports after we update to a new version. this does not go away on a restart and it happens to at least 4 users on our team. see below
  2. We are using the SE50KUS (208V) inverter. Getting an error when i assign 2 strings (1.39DC/AC) ratio to it. Error says i cant go over 1.35 dc/ac ration. this does not seem right and i cant find out how to change it.
  3. hey PVsyst. tabbing through the albedo table no longer works correctly. this is an issue after .14.
  4. this is also happening. all after update .14
  5. Hi all, my colleagues and i are having errors when printing reports in the newest update. .14. the reports are either blank or the loss diagram is jumbled.
  6. is the solution to "ungroup" the array and then set altitude per individual row?
  7. Hi all. i have imported topo data and generated this shade scene of trackers. when i click "set auto altitude" at the highest point, the trackers do not properly follow the slope/topography. how can i fix this? less important question - the area with the highlighted streaks is always white space and i can only see the shade scene on the bottom left of my screen. why is that??
  8. ok, still not working on this project
  9. yes, "enable shadow casting" is turned on. still no shading effect
  10. hi, i am having issues with near shading scenes in 8.0.5. the shade is not being calculated at all. 0%. we put a tree adjacent to the carports and it is still reading 0% near shading loss. a few iterations before, we were getting the near shading to work. we tried the same project on 2 separate computers. This has happened on a couple other projects this week. see photos below. thanks!
  11. we are getting this on projects that were setup in version 7 but now being simulated in 8.0. can anyone help with this issue? we cannot run any simulations with 3D scene. "an orientation needs a representative tracker to be defined for the diffuse shadings calculation"
  12. Hi, i am wondering if there is a way to get the output of each inverter in the 8760 file to fill out the table below:
  13. Hi, I am having an issue running and east west configuration with imported terrain. it looks like too many configurations. can i have some help?
  14. Hi PVsyst team, I have 3 monitors and every time I open a new window on PVsyst (for example I click on 3D scene or run simulation) that new window opens up on another screen and I have to drag it over. it seems so random. why would it not all stay on the same screen? Thanks, -Rex
  15. that worked. thanks!!
