oliver jr
  1. Hey Daniel, have you found out the answer regarding the dashed box and "Irrad. scale 1:2"? I noticed the same thing today and I haven't found an answer to it.
  2. If I understand correctly, then it is not possible using only PVsyst to get the rows distance automatically set? This is the top view that has a constant distance between the rows: sample top view On 3D view it's possible to see that the ground is sloped in all ways and in east-west direction it changes the tilt of the tables: sample 3d view This screenshot is from a software called PVCase, where it automatically calculates the distance of the rows according to the slopes and I would love to achieve the same results with PVsyst :)
  3. Hey guys! I'm starting to work on a hilly project where it would be best to have the distances between tables generated according to the slope of the ground. Looking from the south, when the slope is going up, the tables need less distance between each other and vice versa. I already generated a 3D sample project using a XYZ-type csv. file and I can define the area of the tables which adapts to the ground on the east-west direction but the rows' pitches are a constant value. It should possible be with an Autocad plugin called Rated Power and I also think Helios3D, but I can't find the function for PVsyst... Thank you! Oliver
