Mr. Mermoud, Thanks for your reply. You are right that you can model it in the 3D tool, but in the report there is no difference in production between 0-degrees, -1-degrees, and +1 degrees, when we would expect even some small difference. Additionally, the "Axis Tilt" on the first page shows 0-degrees, not 1-degree. I have attached a couple images of reports, the +1-degree images indicate that although I used a +1-degree tilt in the model, it was still simulated as a 0-degree tilt. The +2-degree simulation shows that the simulation was done with the correct tilt, with a corresponding change in production.
