alich90
  1. Hello! I am having difficulties understanding how the grid limitation at injection point option works, and in which way it affects the inverter output. I have two models that are exactly the same except for the grid limitation. Scenario 1: No grid limitation Scenario 2: grid limitation that is higher than the sum of the rated power of the inverters. Hence it should technically not affect the output of the inverters. The grid limitation is applied at the injection point. In the losses diagram however, the "Inverter Loss over nominal inv. power" in scenario 2 is 0.5% lower than in scenario 1. The "Unused energy (grid limitation)" is 0.0%. How is having a grid limitation that should cause no effect making the inverters have a better output? Thank you!
