Michele
Everything posted by Michele
  1. Hello, does someone know if it makes sense to decrease the "fraction for electrical effect" percentage (i.e. from 100% to XX%) to take into account the supposed better behavior of BC modules (Longi, Aiko, ...) in terms of electrical mismatch induced by 3D scene shading (for a utility-scale PV plant)? A manufacturer proposes to set the fraction to 70% according to its investigation and some laboratory tests by TUV, but I'm not sure they can completely trusted. Did anyone encounter the same issue/doubt? Does PVsyst team have any suggestion on how to handle this in PVsyst (if possible) and if make sense to set to 70%? Hope to have any feedback. Kind regards Michele
  2. Hi dtarin, thanks for your reply! I tried just to be sure but nothing changes...For a 20 MWp plant, simulating horizontal trackers in backtracking with a 3D scene or not (unlimited HSAT) doens't make any appreciable difference in results. This is because the whole shading factor table for beam will be always zero in both cases thanks to the (ideal) perfect backtracking and because the edge effects may be neglected for medium/big plants. The module strings table shows greater values. I was interested in the linear shading table because that's the starting point in any case, trying to figure out how those relatively low geometric shading factors (shaded area/total area) can produce such a high loss, when the irradiation is expected to be low. Anyway, I'll try to play with the tool you suggest...thanks!
  3. Hi, I'd like to share a strange result that I really didn't expect and don't understand at all... I ran two simulations with trackers and monofacial modules: one on flat terrain (for simplicity using the mode "unlimited HSAT") and another using a 3D scene with slopes imported in .pvc. Both in backtracking, keeping all the remaining simulation's parameters the same up to the MPP input stage. As you can see in the screenshot below, the flat scenario performs better than the sloped one. Starting from Gpoa, the main difference is due to a HUGE -2.61% of electrical mismatch effect (~half of temperature losses), that decrease the 37.88 GWh (higher than the opposite 37.29 GWh thanks to lower AOI basically) to 34.32 GWh (lower than the opposite 34.72 GWh). Now, the strange thing is that the topography is towards south (favourable) and almost regular (assimilable ideally to an inclined plane). The GCR doesn't vary much in the backtracking management tab (52%), so the backtracking should work fine. The question is: how is it possible (with backtracking, on an almost regular topography) such a underperformance (-2.61% on yearly basis) even if the corresponding shading table has some non-zero values only for very low solar altitudes and/or high azimut (sunrise/sunset). In these cases the irradiation should be low and then its weight in the overall mismatch contribution, no? Hope the doubt is clear and I'd be very glad if someone can clarify or share their thougths about this. Regards Michele
  4. Good evening, I have a question about the treatment of the 3rd component "horizon brightening" of the Perez model for what concerns the shading, as reported in the release notes on the website. Is it treated like the beam/circumsolar components (purely geometric-analytic shading factor varying with sun position and calculated dynamically) or like the isotropic diffuse/albedo component (constant shading factor depending only on the system's geometry)? Or even, as it's coming from the horizon, in the case of multiple shed rows, is it null except for the first one? Hoping someone may answer my question, Thank you Best regards, Michele
