esaretta
  1. Thanks for your kind answer. Regarding the creation of sub-arrays, it a way to solve the problem. However, it is not representative of the real BIPV project and it means that a different inverter has to be selected. Do you have any other suggestions? Thanks for your attention!
  2. Hello everyone! I am trying to simulate a BIPV facade where there are different PV module's models. These different models are needed because we need to customize PV modules to suit the facade accordingly to architectural shapes. It has been decided to realize strings with optimizers connecting different module models. To give you an example: -> string #1 > 6 optimizers, where each optimizer is connected to 2 modules "model A" in series > 8 optimizers, where each optimizer is connected to 3 modules "model B" in series The voltage of the 3 modules "model B" equals the voltage of the 2 module "model A". The optimizers, indeed, are of the same model. Is it possible to model a string made of same optimizers connecting different module' models but with the same electrical characteristics? Thank you in advance for any support you could give me. Best regards, Erika
