samirahmad
  1. Team, Recently imported a DAE file from sketchup/skelion to my shading window, which came out fine. The drawing was also correctly scaled. Also defined the module active area as identified by the pop up menu that shows up once you import a DAE file (asking me to select the PV module area) which i did. Table also calculated without any problems, however in the PVsyst simulation report the GCR (Ground Coverage Ratio) is coming out to be 103% (which cannot be true) ? Need help why it is coming above 100% ? The Calculation happening at backend ?
