Mrodriguez
  1. Hello Im trying to design a solar pv plant using a Y-connector, when using this type of connector two strings can be connected in parallel and combined, towards one string input in an inverter. see picture: Y-plug and Y-socket We got approval from manufacturer to use this component. However im not sure what is the best way to configure the extra strings in the simulation. I am thinking of two different methods: Method 1: Within system configuration. Disable the option of "use multi-mmpt feature". This would allow me to place as much strings as desired in one inverter. Method 2: Modify inverter file, to add more string inputs, while keeping the same number of mppt's. Are any of these two methods valid for simulating extra strings using Y-connectors? Or do you perhaps know a different way? Thanks in advance for the support and time invested.
