hcolin
  1. Hello, After importing GHI measurement, I get abnormal values of transposed irradiance for vertical modules facing East (it seems correct for West, or maybe even underestimated): irradiances over 3000 W/m² ! I use Hay model (but it is similar with Perez) am I doing something wrong? thanks
  2. thanks for your quick answer 200m would be fine for my study (PV blocks of 5 MWp) regards
  3. in the shading scene construction/zone editing tool, the pitch is limited to 100. why this value? could it be increased ? it is worth it when implementing blocks or array in a large area (and not only modules or module strings) thanks
  4. Hello, I ran a simulation with a centralized inverter and DC optimizers. in the loss diagram, the mismatch loss (modules and strings) is close to 0%. that is fine. I ran a similar simulation with string inverters instead and still DC optimizers. in the loss diagram, the mismatch loss (modules and strings) is higher than 3%, as if there is still a module mismatch ... I don't understand why? Could you help me? thanks
  5. Hello, I defined a PV array made of several sub-arrays (different types of module, same inverter) can I have access to the results of each sub-array to make comparisons? thanks
  6. I am running a simulation with Tigo's TS4-L UHD-core DC optimizer. is it or will it be possible to modify the maximum output voltage (clipped to a fixed voltage), i.e. 42.1V ? Tigo says it can't be modified on request during manufacturing. so how PVsyst could fit to a new value? regards,
