norin
  1. I use PVsyst V6.78 version. I would like to simulate the mixed orientation sub-arrays by 3D model to use 1x1000kW inverter(1xmppt) connected two types of orientation sub-arrays without/with optimizers. When I simulate without optimizers, I can select the ratio of Orient#1 and Orient#2 in "System" menu, which shows scroll bar to modulate the ratio. I also made two table zones and set modules in 3D model in "Near Shading" menu to fit the same ratio of orient #1 and #2. It worked. However, when I simulate with optimizers(string type optimizers), the scroll bar to modulate orient#1/#2 does not display. Is there any method to calculate 1xinverter(1xmppt) connected two types of orientation sub-arrays with optimizers in 3D model?
