I've tried using different modules to attain different results, but the "PV loss due to temperature" is always 10%. The site is located in South America, Brazil. As recommended, I am not going to mess with the pv modules specs, but I believe this might be a limitation being caused by the the default parameters set by PVsyst. If it is indeed a hidden parameter that must be changed in order to attain accurate results, please help me change it as well as recommend parameters that are used in Brazil. Thank you!
